John And Loma, Does This Work?
1 year 1 month ago #345
John And Loma, Does This Work? was created by B4D2
Trying to link John's video from FB.
(2) Facebook
1 year 1 month ago #346
Replied by B4D2 on topic John And Loma, Does This Work?
- jbernd56
- Thank you received: 9
1 year 1 month ago #347
by jbernd56
Replied by jbernd56 on topic John And Loma, Does This Work?
Thank you Bruce. I couldnt get it saved to the right format. At the time of the video, I had only changed the mag and cleaned the sediment bowl. I think the carb needs gone over and a friend thinks it needs to advance the timing a schosh.
I have since taken off the radiator and repaired it and am going to install the generator and re-wire.
- Ianoz
- Thank you received: 1
1 year 1 month ago #349
by Ianoz
Replied by Ianoz on topic John And Loma, Does This Work?
Hi Bruce .Neither of the links would open for me.I am logged in to facebook , so should be able to view .
John , Probably the easiest way is to upload on to You tube .Then you can share a link to the video .
- loberndKS
- Thank you received: 4
1 year 4 weeks ago #350
by loberndKS
Replied by loberndKS on topic John And Loma, Does This Work?
Thank you. I'm not sure what John tried. Will pass it along.
